- Sep 28, 2013
- 4,395
This has been on my list for a long long time, as I've often struggled with Z height on my 6x26 mill, even more so now I have a rotary table and dividing head.
Started with a chunk of mystery metal 6" OD and around 3/4" thick. This was (more on that later) going to be the male end of the adapter.
Cut off what I didn't need and turned the stub
Turned it around and turned down 1/4" or so to fit the mating part
Then turned a ring to fit the stub, to be JB welded in place
Started on the body. It's 6" od, 5" id with a 3/4" thick end, so really stout. I needed to cut out the female hole. Turned a center for support.
Well that didn't work, snapped the end off my trepanning tool
Hole saw didn't work either. Chain drilling the hole with 1/4" solid carbide drills didn't work very well, one drill lasting 2 holes. After two dull and one snapped drill it dawned on me (I'm slow sometimes) that this whole piece is through hardened. Muthatrucker!
