- Oct 21, 2017
- 504
I needed to turn an outside radius larger than the capacity of either of my radius turning tools on some 1/2" round brass, the quickest and cheapest solution was a make a longer tool holder for my horizontal radius turning tool, it's about 3 times the over all length of the standard tool holder and takes the same insert and screw, you can just about see the carbide insert under a pile of brass powder!
I made a test extended tool holder in Aluminium but it worked fine on brass so I'm not bothering with steel yet, the vise grips provide both a handle at an adequate radius to control the tool and extra outboard mass to prevent vibration, quite deep cuts are possible, the job in the shot took 4 cuts plus a spring pass.
- Nick
- Nick
