4 jaw chuck
snoopdog
H-M Platinum Supporter
Dec 27, 2021
740
So, looking for a 4 jaw chuck for my lathe, 2.25x8tpi threaded spindle, 8 or 6 in, preferably 8. Looks like I'll have to buy a plain backed chuck and a threaded backplate, if I end up buying new. I have an 8 in 3jaw and backplate that I haven't drilled, because I really haven't needed the bigger chuck yet. That 3 jaw has the 2 piece jaws, and finally I'll get to my question, what are the advantages or disadvantages to that? Is that something I should look for in a 4 jaw? Thanks ahead of time.
The 3 jaw with 2 piece jaws is nice for a few reasons, you can change from outside grab to inside faster and easier and best of all you can get and use soft jaws. I don't know if 4 jaws come with 2 piece jaws, but a 4 jaw is good thing to have.
I'm not seeing any 2piece in the 4jaws.
What size lathe do you have?
Hmm, hard to say from the pic. Doesn’t say one the lathe? Just wanted to make sure you didn’t buy bigger than you need or is usable. My 9x20 came with a 4” 3jw, 5” 3jw and 6” 4jw. I have to be careful with the 6” with the jaws opened and clearance to the bed. I think a 5 or 5.5 would have been better but it works. Bigger is not always better.
I measured it at one time, but not sure now, its close to 14 x 40, 12 x 36 etc
Another advantage of the 2-piece chuck jaws is that you won't lose one or more of the inner or outer jaws when you store them in that "special place". The primary advantage of a 4-jaw independent is that you can remove a part, reinsert it to perform a different operation and still be able to adjust for .000" or less runout.
Several brands of 4 jaw chucks do come with 2-piece jaws. If you do a quick Google search and click on "images" you'll see several vendors offering several brands with this feature.
4 jaw doesn’t need 2 piece jaws because the jaws are reversible unless it’s a scroll chuck. The reason is the scroll gear in the scroll chucks will only work one way. Look inside your 3 jaw, you’ll understand. Or look at the back of the jaws, at the shape of the gear. On 3 jaw or any scroll chuck the gears are curved, on chucks with independent jaws they are relatively straight.
Chuck
Chuck
Yes, the jaws on my 6in 3 jaw are not reversible.
