I've been using 30 weight NON-DETERGENT oil on my Atlas 10100 Mk.2 since I got it since that is the only non-detergent oil I could find locally. Temps. in the shop are usually above 70F and frequently 80-95F range. Since shop isn't climate controlled I keep a coat of oil brushed onto all machined surfaces to guard against rust. I'm using chainsaw bar & chain oil for the gears as the viscosity is higher, but not quite a grease. IIRC grease was not to be used since it could potentially grab & hold chips cycling them thru the gears ??
My thinking on the bar & chain oil was that if a moving chainsaw chain manages to not fling all of it off then the lathe gears could use it without much trouble. The 30 weight ND oil I can find at the local tractor supply store. I haven't seen any 20 weight ND oil stocked at the O'reillys or Autozone stores which other than Wal-mart are about the only local options here. Thanks
