- Apr 8, 2013
- 2,021
Na, that's all setup time. 20 minutes to setup, 20 seconds to cut, then next tool. ya da ya da3 hours? Must have had many coffee breaks! Your new part should outlast the door!
I dunno, I thought 3 hours was good! Tuff little part to hold without lots of setups. That slot was too deep for my little end mills to reach from each end so I had to use a .110 drill in the deepest part and then go almost to it with a thin T-slot cutter. Then I had to file out the sliver between the drilled and milled holes. I still would rather just pay the 3 bucks!3 hours? Must have had many coffee breaks! Your new part should outlast the door!
