A couple of things to consider, a 4J independent is often used because you can dial out any runout if you need to be spot on with regard to TIR The downside of many 4J chucks is the jaws tips are often wide and rough, i.e. made to hold bigger stock. Both a 4J and 6J scroll hold a piece by opposing jaws, if the sock is not perfectly round and symmetrical it may no be firmly held. Probably less of an issue with thin wall tubing because it will deflect. Truth be told similar to Ray C, I have had smaller round stock squeeze through/twist from the jaws on my 3J scroll. One reason why I prefer a collet chuck for smaller round stock, but with one caveat. A couple of us use a combination 4J chuck, which has a scroll section with independent jaws that ride on the scroll plates. The jaw tips are 0.2", so you can hold quite small stock securely and you can adjust the pressure of each jaw independently and get the TIR way down. The scroll will repeat to better than 0.002", this is dependent on the pressure of each jaw. I use my 5C most of the time, followed by the 4J combo, much less frequently a 3J scroll Set-True if I have to do a lot of repeat in/out of the jaws, and a 4J independent rarely only for bigger heavier stock that I need to hold securely.
A 4J scroll would be low on my list (i.e. bottom), I would go with a collet system first, a 4J independent is more versatile while a combo offer the best of both. Of course all this is dependent on the type materials and size you are most frequently turning, along with the lathe size.
