Does anyone have (workable) dimensions or drawings of a female 3/8" drive square hole? (other than Engineer's Edge https://www.engineersedge.com/hardware/square-drive-tools.htm - which I am having trouble understanding). I will probably want to drill the corners before milling so I need to figure what size (and placement) to drill the corner holes.
If I understand Engineer's Edge right it would take a very small drill (to get the proper radius) - like .17x", which means I would have to finish the sides of the hole with a 0.125" end mill. Does that sound right? I'm not sure I have an end mill that size long enough.
I could probably just measure a socket (or weld a cheap socket to my special tool) and go from there but I was trying to dear it up from scratch & got curious - and as always - bull headed.
