Good day all, Just started to test by Bridgeport which I recently converted to cnc. I am using the forth axes for indexing hence 3.5 axes. This was one of those machines that had a hydraulic tracer so the machine already came with ball screws. However there are two nuts per axes , and setting the correct pre-load is proving to be a task. I got this machine already stripped so the re-assembly is really a bit of trial and error.
