2"x72" belt grinder
Will be watching this build. are you going to make or purchase the wheels
I have the wheels cast already. I used my backyard foundry.
This was from the dogs ss water bowl, it will be the driver.
A "Bushes " baked beans can provided the idler wheels.
I will be building 2, as a friend traded some wheels and tires for one.
Jake Parker
What did you use for the melt. Needs to be old cast stuff primarily or else it will be, I tried cans one day did not do good. Extruded also did not go good. That one does not look to bad at lest not full of pits like my melts.
What kind of motor are you going to use.
I bought a 2” x 12” aluminum bar from Speedy Metals for $15 to make mine. Also ordered some 3” too. Should be here tomorrow. Pretty darn good prices it seemed.
The best aluminum to use for casting aluminum is cast aluminum scrap. The alloy is, by definition, designed for cast aluminum.
I used pistons.
I had a chance to sneak out to the shop and weld a little more.
Maybe tomorrow will merit me a little more time to work on it.
I have 2 treadmill motors, and a 2 up 1725 single speed. If I turn the drive wheel to 2' circumframce that will give me 3450 SFPM.
Jake Parker
