2-step Pulley Replacement For Craftsman 12"
MikeMc
Dec 23, 2014
37
After getting my new(old) lathe, 101.07381 I discovered that the big 2-step drive had a crack clear through one of the spokes. When I found a replacement on Ebay the fellow wanted nearly as much as I paid for the whole lathe so decided to do it myself.
Starting with a 1.5"x9.5"x12" slab of 6061 AL I cut it square with the table saw and knocked off the corners. I roughly laid it out using DyeChem, compass and rule then went to the drill press to drill and tap 3/8-16 holes for mounting to a faceplate and drilled/tapped holes for set screws to lock it to the counter shaft. While there I used a holesaw to knock out 1.75" holes defining the spokes. This was a big mistake causing interrupted cuts in most of the facing cuts and really slowing things down. Sometimes I'm penny wise and pound foolish but I did end up with four 1.5" long x 1.5" diameter chunks of AL to use somewhere else.
I bolted to a face plate to rough it out, getting near finish diameter, thinning the web to within a 1/16" and drilling the center hole then flipped it over and thinned the web on the other side.
To finish it to size and cut the grooves I mounted it to a shaft and turned it between centers.
After balancing and mounting the lathe runs a lot smootherPulley2Step_BrokeSpoke2.jpg pulleyBuild23.jpg pulleyBuild24.jpg
I took about 2 dozen picks if anyone wants to see them.
MikeMc
Lot of work but it certainly looks good. Should last forever.
Makes ya feel good don't it. Nothing like being able to make your own parts. I know I get the most satisfaction when I fix stuff nobody says can be had or done.
Beautiful work. Given any thought to how much you would need to charge to make it worth your while? I think you could sell a few of them to the Atlas/Craftsman community. The motor pulleys seem to be in demand.
Nice fix Mike. +1 on what Silverbullet said.
