- Feb 9, 2015
- 100
I picked up a 1/5th , double shaft fan motor to use on a project. On the tag, it lists it as 1600/1200 RPM. It uses a 10 mfd capacitor, which I already had. There are only 4 leads. 2 shorter ones, that are taped side by side, and 2 longer ones that are also taped side by side.
One pair appear to come from a set of field windings, wound with smaller gage wire. The other pair look to come from a set of field windings, that are wound with heavier gage wire. I could not figure out how they got 2 speeds from the motor. I only need the 1200 rpm speed.
A thought hit me the other night, that maybe one pair clip to the capacitor, and 115 vac feeds the other pair for 1 speed. Then, you reverse the hook-up to get the 2 speed. (all 4 leads have connectors on them). Does that make sense?? I just don`t want to use the "Tune for minimum smoke" method on this one. --- John
