I don't think I've ever seen square or hex 2js. but I'll keep a lookout. You just can'r tell what will pop up.
I bought a 7" Logan shaper from a used tool guy once. It looked Ok but turning it by hand it sounded like it was lubed with river gravel. I got it home and took it apart. It had about 5 ponds of mud dauber nests in it. A serious cleaning and it was like new, he chain showed no wear at all. Just as I got it up and running,an old friend called and asked me to come over. I knew hw had this South Bend 7" shapper but he wanted a gob of money for it and I just forgot about it.
Well, he GAVE it to me! Now,no one really needs two 7" shapers but I have them and keep one vise at 0 degrees and the other at 90. Works for me! The South Bend is more accurate and will make a prettier finish but the Logan is a beast. Big old cuts all day long when roughing out a piece. I use the SB to cut screw slots in the gunscrews I make.
I can grind a piece of Rex ,with my T&C grinder, to an exact fit on the remaining screw slots so they all match. I would have to buy many $$$ worth of slitting saws to be able to to the same thing with a mill. As for the 2" spacing,it's just a little math to find the spacer block to do any angle. I took trig in the mini semester in college. I had it in High school so it was just a refresher. 9 days straight and the final. Made 100% on it........instructor was amazed. There was a tricky question that no one ever gets it seems,but I did and then told him how to do it better than his method. Now this is a guy with a Doctorate in math! I got a little big head for about an hour or so.......
