- Oct 17, 2018
- 966
I got a Primeweld MIG180. This is my firs time welding since college many many many years ago. Waddya think?
SETTINGS
-1/8" thick steel tubing (1" sq.)
-0.030" (0.8mm) solid wire
-feed rate and voltage settings per the welder instructions (20.3V, 354 in/min)
-100% CO2, 27 liters/min
-240V power
COMMENTS/QUESTIONS
1. I found it hard to make a straight weld when I was making #9-11. These were the very first welds I've made. The rest (the upright ones, not the sideways ones-these are practice from another day under supervision with a different welder) are numbered in the order I made them. How do I make a straight line?
2. I rested the small pieces on the bigger piece and zapped it briefly to tack it on. I did not use any clamps or magnets.
3. What should I practice on? I have some sheet metal, and some more scrap steel tubing, but not much.
4. Are there better clamps that are quicker to clamp/unclamp? I'm using C clamps, but would like something faster. I have plastic spring clamps, but I'm thinking they will melt.
5. Are there better wire cutters that can be used with gloves on? I found my 6" ones tough to open and close with leather gloves on.
SETTINGS
-240V power
COMMENTS/QUESTIONS
