- Jun 19, 2017
- 83
Hey guys,
So far I've only been playing with the mill. (testing my skills?)
Now I have a semi practical project.
I have a Harbor Freight drill press for my hobby room. It has about an eighth of an inch of play at the end of my drill bits. There are no adjustments to make it tighter. The large holes in the housing that the quill travels in are just too big. SOOOOO,
I'm gonna try to make and install a pair of bronze bushings.
I wish I had a lathe but I don't so I'll have to improvise with my rotary table.
I have a piece of bronze bar stock that has to be cut down and hollowed out to make the bushing material.
I think I should leave the ID a bit smaller than the intended result. I can do a final bore after they are pressed in.
When I bore the aluminum drill press housing, how much of an interference fit should I shoot for? (I'm thinking .0005") What would you recommend?
I don't have a lot of room to enlarge the holes before I make the housing weak so, how thin can they be but still be strong enough to press in?
The diameter is about 1-5/8" and they are about 7/16" high.
thx,
Jim
thx,
Jim
