- Jun 5, 2023
- 71
Finally got my new lathe running last night and noticed that the chuck seemed to have a pretty good wobble to it, noticable to my eye. Today I started looking into it. I took the chuck off and put a dial test indicator on the registration face of the spindle. Seemed like it was running pretty true but then I noticed that I could deflect it 3-4 thousandths by pushing up or down on the spindle threads. Also about that much if I push from the front straight back. This is by hand with some force but not alot. Thats not correct is it?
Also seemed like it was pretty noisy. Low bumping noise. I disengaged the belt to the spindle and the noise was still happening. Seemed visually like the rear pullies were bumping up and down a bit every rotation. Took off the belt to the motor and the motor seemed pretty quiet. When I wiggle rear pully shaft by hand I can move it up and down about 1/8". Both bearings seem like they have a lot of play in them. Thats not correct either or is it?
