- Mar 13, 2017
- 55
Hi, my 1440GT which is now about 5 years old with very little usage sorry to say life got in the way. My problem is when mostly running on higher speeds oil is leaking from rear spindle bore, shaft with small gear right below spindle and the lower shaft as well. I have had some small leaks from new but now it’s getting much worse. It’s to the point that it’s making a big mess and getting on belts. I thought maybe vents where clogged and it was building pressure, that wasn’t the problem. Also the rear of spindle does not have a seal to my surprise.
Anyone have any idea what’s going on? I’m kind of stumped.
Thanks
Thanks
