@Ken226 - My compound doesn't move that way.
This is as far to perpendicular to the X axis as it gets...
But I find it odd that if I spin in the other direction.... I can get the hand wheel on the wrong side of the bed.
Or a pin stopping it, or you just need to loosen it further because the bolts holding it down are getting caught on the hole you pull them out of.Take it completely apart and you’ll find some trash in there stopping it from moving in a 360° circle as it should
@xr650rRider - I can't turn past the 60 degree mark. See first photo in above post.
