My lathe is finally alive...
Thanks to this community, I finally have it wired up with the VFD and some of the common options other users have integrated into theirs. I never would have been able to do it without @mksj and other reference docs posted on this form. Especially the VFD config parameters with the Hitatchi software.
Just having slow start and braking is well worth the extra effort over my initial single phase motor option.
I went a different route on wiring, entirely re-wired and using AutomationDirect P1000 series and the P1AM-100 arduino based controller for switch inputs to relay outputs to VFD. This is mostly an exercise in learning and because I wanted to.... it's not totally justified. I may add an hour meter, possibly my own version of ELS and automatic two stage braking at certain RPM.
I ran through all gear selections for 3 minutes to run it in per manual. I noticed at higher rpm there is more noticeable whine in forward than reverse. Mostly coming from the QCGB gears. I took the QCGB front panel off and was surprised how much grease I did not get out initially from below... plus the gears had over spay when they painted the machine. After quite a bit of cleaning it was noticeably quieter at higher rpm. I'm curious to see how effective the drip oiling mechanism will work.
Pics show my setup... and if I did it all over again, I'd just get one large enclosure and put everything in there... it would simplify having to route my wires externally from PLC to VFD and 24 power supply for the main logic/switch circuitry. I started with intentions to have all my wiring be super neat, really professional... but only working on this a couple hours a week, this past weekend I just had to get it up and running. If anything, I learned a LOT throughout this process.. basic circuitry, PLC stuff, panel/enclosure layout. I have a new appreciation for thought and amount of work this takes.
I used a HF US general 72" tool chest, shortened the draws on the left side to accommodate my VFD enclosure.... that was more work than worth it in the end... should have just used the entire drawer space and put a door on the front or larger cutout on the end w/door for servicing. Oh well. I at least get to keep those drawers which are only 6" deep for small stuff.
Still need to mount DRO and once in place, level/align it. For now, using it as is! There's always time to tweak my setup.
