- Oct 4, 2016
- 7,160
I never ran the machine when changing Norton feed rates, but have been hearing a noise that was getting louder, and was afraid I would have to follow David Best's tear down. Todays exercise was to pull the front plate off of the gearbox, and observe, and while I could watch I found something. I found that in the B position 2 bigger gears are touching the shift lever body, I ran the machine at 90 rpm, and found the lever was bouncing. I closed off all openings, and made sure chips would not escape the pencil grinder, and fixed that issue. I also had the power panel off, and discovered a blocked distribution tube, and fixed that too. I put it all back together, and could still hear a noise I didn't like, and found the big gear in the front had too much backlash, loosened the adjuster, snugged it up, lightly greased the gears, and all is quiet now. I'm so glad it did not have to be torn down. Happy camper here
