- Jun 15, 2013
- 1,199
So today I was turning a piece of 4140 turned ground and polished 2 in stock at about 400rpm taking .030 DOC and when I got closer to the headstock it would stall out the motor. Using carbide. So I lightened up to .020 and it still stalled. Using power feed with the shortest cut per rev. So I upped the rpm a little and it no longer stalled. However I realized that to get to my final od is gonna take FOREVER. Has anyone increased their hp and by how much? What are the risks of the extra power? I would assume the little cheapie gears would be at risk. I have access to a 1.5hp 3 phase motor that I am seriously considering installing. Using a VFD to control the motor. BTW my lathe currently has a 1/2hp motor wired 220v. The motor I could use is a little longer than the current motor but I have no problems with cutting a hole in the cabinet to make room for the new motor. My lathe is an underneath drive. looking at picture my lathe was made the year before they added the lever to the power cross feed. Mine has the pull knob. Other distinctive features like the compound add to the time period.
