12" spindle gear
oldschoolcj5
Mar 3, 2014
8
hello
this weekend i had time to play on the lathe. here is the latest upgrade i made for the lathe. the spindle gear on my lathe had quite a bit of wear. i had some gear stock that was the same tooth count and pitch as the lathe gear. so i cut the some stock off and bore the hole to size. then used a boring bar and carriage to cut the keyway. here is a pic of the finished gear.
stephan
Nice!
What is the material?
Who is your gear bar source?
this stock was 1018 that the tread was rolled. so it work hardened the gear surface which should help with wear. unfor i cant remember where i picked up. it was a 2 ft piece they had left over. i still have a bout a foot. i have one more gear that i made because since i was set up i made 2.
stephan
