I needed a follower rest for my 10", and after looking at how much an Atlas one was running on eBay I thought about making my own. There were various improvements I wanted to make, such as being able to put the followers on either the left or right side of the cut, depending on what I was doing.
I had something sketched out when I decided to go nuts. I bought one of the T-slot cross slides from MLA (A-11 from statecollegecentral.com). It was about $88 with shipping and the extra material for the gib, etc. It's an unmachined iron casting, so I'll have to finish it before I can use it.
I then ordered one of the follower rests from Little Machine Shop for the 7x10 mini-lathe, which is about $45 with shipping.
All I need then is a spacer block to mount the follower at the correct height.
I just ordered everything three days ago, so nothing's here yet...
Still cheaper than eBay, plus I'll be able to mount a toolpost on the back with a cutoff blade when I'm not using the follower. There should be enough room for an adapter to mount my compound to the T-slot table, though I'll probably have to make a lower-profile toolholder block, or cut the one I already made down to fit. I'd like a nice wedge QCTP, but I blew the tool budget for a while...
