11x36 Delta-Rockwell lathe speed indicator is missing a piece of linkage.
corbinace
Dec 21, 2023
26
The piece at the top that runs the geared shaft for the pointer is missing. Could you take a picture, so I can see if it is possible for me to make one?
It would attach to the lower upside down “L” shaped rod in picture. I believe The missing part would go up through the hole above and then have a flat toothed rod that runs a round gear that is attached to the pointer axle shaft.
I think I am only missing the upper rod that has the flat toothed area.
