- Aug 23, 2014
- 222
Doing a bit of work on my countershaft, have looked up the belt tensioning instructions. It say's to set belt tension with tensioning lever/rocker shaft in the middle position. The lever/rocker on my lathe has the crosshole drilled @ 55deg instead of 33deg(relative to deeper slot) as per atlas drawing, so will not rotate far enough to reach around to full diameter area of the shaft due to my rear cover. I'm assuming that mention of a "middle" position along with other information, in this case means that there are three positions, off,on + heavy duty. I haven't really looked at this 'til now, had always figured on just the two positions. So now will have to modify existing to work properly, possibly make another. Thoughts, comments or ideas welcome.
