When I took the headstock apart, everything came off the Spindle ok but the front bearing and dust cover remains stuck on the spindle. Is it ok to press these off? Am I missing something? Also, the apron rack seems to be glued to the bed on the ends. All six screws have been removed but both ends are still attached with glue of some sorts? Is this common practice? It must be epoxy or similar because it will not budge. Any suggestions? I do not want to damage it. Thanks, Gene
