While practicing 0.002 cuts on a 3/4" -10 thread, I noticed the lead screw slipping. The head had back gears engaged and the slowest speed. I removed the lead screw and collar on the quick change gear box. The key in the collar was in good shape. The keyway in the screw was excellent. Putting a wrench on the collar and one on the screw, the keyed insert inside the collar will slip with moderate pressure. This may be by design so damage to the qcgb is avoided if the carriage hangs up. My questions are: 1. Is this keyed insert in the collar supposed to slip? 2. Is there a service manual available for the carriage to check gears, clearances and tolerances?
