- Apr 12, 2013
- 562
Upon disassembly I now see that the 4 speed pulley on the jackshaft has a keyway. I bought a D shaft as a replacement since all I saw were set screws.
Do I use the existing set screw on the flat of the D shaft (and forget the key) or do I put my jackshaft back together (no small trick, lots of burrs and shaft damage to drive over) and try and cut a keyway slot in my new shaft?
