- Oct 14, 2014
- 2,115
The casting that holds the taper attachment to the bed is often broken on the 10EE lathe.
Over on PM, you can now buy this part as a raw casting for $55
NOT MY WORK. Just and FYI
<EDIT> My mistake similar thread previously posted.
10EE Taper Clamp casting possibility - Martin Model
The casting has a couple of issues to use "as is". 1 There is a triangular pocket on the bottom side of the arm. The casting is not smooth inside the pocket and the foundry would have a hard time pulling the pattern out with the sand in one piece. It would probably break off and leave no...
www.practicalmachinist.com
