Hi all,
I have a round dial machine that is missing the motor and drive guts. What I do have is the spindle pulley and gearbox. The pulley uses a flat belt and measures approximately 5-1/2" in diameter. The inverter motor I have selected for the VFD conversion is 5 h.p. rated for 1750, however the data plate says MAX RPM 6000.
So, hear is my question...What diameter drive pulley came standard on these machines and should I use that size going forward? The machine has a RPM dial that reads 0-4000.
