- Dec 29, 2013
- 321
I have been wanting a magnet back indicator similar to the one Abom uses on his lathe. While puttering in the garage tonight, I got an idea on how to make one. I used an old Hard drive magnet and drilled and tapped a 1/4-20 hole through the back. The hole on my old Starret 1" indicator is right around 1/4 inch so the fit is pretty snug. I put a 1/4-20 setscrew through and used a hex nut to tighten up the indicator. Why didn't I use a regular scew you ask? I didn't have one laying around but I have a couple of setscrews left over from rebuilting the cross slide and compound on the lathe.
Here are some pictures:
