10" Atlas carriage modifications
iron man
Feb 7, 2013
792
I was tearing down my Atlas for the second time in 20 Yrs it was time to clean and paint. After I made the tailstock modifications I thought I would move on to the carriage. I noticed from years of neglect from prior owners the bed was in bad shape it was straight but had bad wear spots so I spent about three days scraping it straight and smooth again after a lot of measuring checking and double checking it is done. It turned out nice but I would never want to do it again.
- - - Updated - - -
Notice the big gap under the carriage?? the carriage does not use very much of the way I built a small lathe before and it would cut much better than the atlas because I used all the surface area I could when I built it. I can do the same for this one as usual all mods can be changed back to stock.
- - - Updated - - -
There was some slight wear on the carriage so I flipped it upside down and set it up in my GO727 to mill it flat again but before I did that I cleaned up the bottom and purchased some loctitie epoxy it is twice as strong as JB Weld I was going to put a couple of screws in it but after it was set up I could not remove it without damaging the plate. The machined area will now be in contact with the bed is gives you about 1" per-side about 3" wide.
I then milled the surfaces so everything was flat again.
- - - Updated - - -
After a little paint and a lot of cleaning I reinstalled it and man what a differance it just glides up and down the bed with more contact surface it supports the weight a lot better.
But then I did not like the cheap thin Gibs and I really hated that you had to use shim stock to make them fit. I dont know about you but I can never seem to get that right so I thought I would change things and make them better.
- - - Updated - - -
For the rear gib I selected a piece of cold rolled 5/8 X 1 1/4 I then milled one side for a brass gib to go into. the extra (meat) will stiffen the carriage and it will allow me to make infinite adjustments. After I machined the slot for the brass gib I drilled and tapped for six 1/4 NF set screws.
- - - Updated - - -
Her is the finished product the rear gib is brass and is 5/16 x 1/2 and is adjusted by six fine thread set screws..The gib under the apron does not allow much so I took a piece of 3/8 X 1" brass bar an machined it to fit I then put set screws in it the original gib is only about 3/16 thick.. I will show you later how the adjustment is done.
- - - Updated - - -
This is the gib under the apron I tried to make one like the rear but there just is not enough room under there so this is what I come up with. You tighten down the three bolts till the carriage is tight then you just crack the bolts loose enough to get your desired fit you then tighten all the setcrews and re-tighten your bolts. The setscrews take the place of any shim stock and this will give you a very fine adjustment when there is not shim stock thin enough. Works great!
- - - Updated - - -
Here is the rear gib before paint on its test fit it performed as expected both gibs are much stronger gives the carriage more support and more surface contact than the stock ones. You can get a tigher tolerance with this setup and yet it slides up and down the ways with little effort.
- - - Updated - - -
Here are the stock gib plates next to the modified ones the new ones are more than twice as strong as the stock one and twice as thick it adjust much easyier and the brass glides along cast iron real nice. As I stated before I all ready built a lathe with these features on it and have tested it for years it works well and is well worth the time. Well thanks for lookin time to clean my shop now its a mess. Ray
100_0626.JPG 100_0625.JPG 100_0627.JPG 100_0635.JPG 100_0629.JPG 100_0632.JPG 100_0631.JPG 100_0634.JPG 100_0633.JPG
One more point the rear gib is 5/8 x 1 1/4 it helps stiffen the carriage it also adds some weight which will help reduce chatter. vibrations ect. I finished putting the carriage together and all mods have worked better than anticipated the brass plate I used for the carriage is 1/8 thick I wished I would have thought of doing this sooner.. Ray
Ray--I am not an atlas lathe owner, but those really look like professional improvements--I will stop by your shop this year and I will check out your homemade lathe--I have seen a few and have always thought about making a small one--your atlas lathe looks very nice--Dave
Thanks Dave I was beginning to think no one was reading the article. The small lathe I built has hard chromed bed ways and the bottom of the carriage has a brass plate that can be removed and replaced. Unlike the Atlas mine has two different drives one off the lead screw and another with an in and out clutch. The lathe was roughly based off of a leblond regal lathe stop by anytime. Ray
That should be a great improvement to that lathe. Very well done and documented. Thank you.
"Billy G"
Thanks Bill I will keep improving on the Atlas because it is all I have and I like the machine and I can turn out some pretty accurate work on it. Ray
Very impressive :thumbzup:
well above my skill-set but something I would love to do in the future. I also need to do some reading about scraping the ways.
Ray - I don't suppose you fancy coming over to a small, cold & very damp island for a visit so you can modify my 10f ? :anyone: :tiphat:
Very nice work Ray, those shims really are a pain to get right, page bookmarked for later..:thumbzup:
Bernard
Re: 10" Atlas carriage modifications
It is 35 below wind chill here right now cold and damp dont sound to bad. The mod does not take much just the setup time to mill it I suppose if yours does not need milling you could just set the carriage on top of of a well epoxy'd brass plate and let it set up the way it is. Ray
- - - Updated - - -
Bernard
It is a big improvement tonight I got it all put back together smooth as silk it is well worth the time.
Had to get my daughter to show me how to reply! Not good on the computer. I have a very old Sebastian lathe and a Atlas 10F. Drill presses and a homemade milling machine. Might get my daughter to add pictures at a later date. I'm a retired heavy equipment mechanic from Cape Breton, Nova Scotia, Canada. Been around machine shops during my career. Tired of wrenching enjoying machine work more.
