My first real combined lathe/mill project, a set of tube joiners for 1.75" x .120 tube
They'll be going into my panhard frame mount brace on the front to allow easy installation and removal of my sump. I still have to turn/mill the second set but only did the one as a test to see if i could.
I didn't run off any drawings, just kind of ran with what was happening. The next pair will be to a drawing which i'll do in the next few days (but won't make them for about a month as usual).
I didn't think of taking any happy snaps while turning down the stock but here's a few i did get while in the mill.
Starting to remove some material on the mill from one of the halves
junk pile
two halves with the bulk removed
Slotting the halves. The next pair will have only the one slot. Not sure why i did two as the chance of both taking load is slim to bugger all. Especially when I'm machining it!
I then stuck the two together and put them back in the vice. Followed by milling a slot to counter sink the two M8 cap screws.
After pilot drilling, drilling and counter boring the top half, I cut a thread in th elower half and checked with a pair of cap screws. These are a stainless screw but i'll be using a Grade 8 or 12 high tensile screw when it comes time to install them.
Overall, I'm happy and will feel safe with them in use. As they are not going into any cage or body armour, just the panhard brace, they only receive load in the one direction.
I've learnt a bit with using the vice and should have used the soft jaw against the non fixed jaw to ensure things stay square. Along with a few other handy things and look forward to the next pair.
Even though the time spent making these vs. the cost of a bought set makes them not worth it, it definitely helps get to know the machines.
junk pile
