- Aug 23, 2014
- 7
I'm making the face plate for a control panel. I was able to cut the SS plate pretty easily, following the advice given by many of you here on this forum - thank you.
Now I need to cut a 1.25" round hole in the 3mm SS plate, to install an emergency stop button. I'm pretty sure brute-force drilling with a 1.25" drill bit will not work - I've made much smaller holes and it's quite difficult. The material hardens very quickly. The only thing that worked well for a linear cut was milling it with a carbide mill at slow speed while constantly moving the work.
What are my best options to make that big hole? I've access to a mini-lathe, mini-mill, drill press, and various hand tools.
The plate size is 8.75" x 3.5". The big hole is not in the middle, but closer to one end.
