- Jan 3, 2013
- 8
I found this website in the hopes of learning more about machining and it has not disappointed me. I have a Speedway 7X12 lathe and Harbor Freight Mini mill that I'm learning to use. Have been a model railroader since 4th grade and always built models, so when I stumbled across larger scale RC construction machines, it was a natural fit for me. Anyway, if you have an interest in such things I recommend www.rctruckandconstruction.com. There are many machinists on the forum and excellent models.
Having grown up with IH construction equipment, I chose their 1970s, 50 ton, 4-wheel drive dump truck as a model to build. I'm using purchased axles (modified), 3-speed transmission (also modified), and hydraulic pump, but am building the frame, suspension, cab and body, and hydraulic cylinders. It has been an interesting build, having to learn use of the lathe and mill as I go along.
This is the prototype 350 Payhauler The frame rails are modified aluminum c-channel.
General layout of the frame and axles. The rear rear spring and hydraulic cylinder brackets Rear spring brackets mounted. Rear springs-Main & Overload. Modified axle housing Rear axle & springs. 1st Wheel completed Trans input shaft & pinion. Transmission modified & mounted. Rear driveline Front Spring mounted. Front axle & wheels. Front Axle & springs. Chassis Milling fuel tank brackets. Fuel tanks & brackets. Cab & Chassis Cab & mirror mount
