- Feb 2, 2013
- 3,903
in some of my work i run into relatively large and strange fasteners.
sometimes how machines are assembled will dictate how repairs and service are performed.
sometimes the use of special tools are a prerequisite to attempt some operations.
sometimes you can copy a special tool, if you are lucky, from a drawing or picture.
sometimes you have to wing it....
Which is what brings me to my point of sharing this story, i need a special jam nut wrench for a 1 1/2" nut.
the wrench had to be relatively short and very thin to avoid a week or so of disassembly, reassembly, retiming and readjusting
of a packaging system. the owners were desperate to get this machine operational as quickly as possible and requested my assistance.
i loaded up the rig with all my ordinance ready for the battle. welders (stick,flux core,and mig), plasma cutter , and all my other normal battle gear.
when i got to the call, the tension was high to get it operational, like yesterday...
A couple cam followers had frozen and kept tripping the main motor breaker as a result.
one of the cam followers is difficult to get to, the other is impossible with a normal wrench without removing other assemblies.
i was able to change out the first follower in about an hour and a half, the second was going to be a challenge because the wrench i had was too thick and a few inches longer than i could get into the space.
i made my own wrench out of scraps i had on the truck, some stainless sheetmetal and a 3/4" x 3/8" hot rolled steel flat and my lincoln stainless mig set up...
a couple pictures.
after assembling Frankensteins' wrench, i went back to work on getting the last follower out.
it was a PITA, but eventually i got it.
it cost them a few hours OT for me and i get to keep the wrench for another time.
sometimes the tools you make are the right tools.
thanks for reading, feel free to post your inventions and tooling solutions.
a couple pictures.
