When I was using my mini mill the motor would randomly bog down and stop. If I reset everything it would begin again and repeat. Eventually it stopped spinning when I turned it on.
I have done all kinds of testing based off of LMS trouble shooting guide. I used a meter to test everything they suggested. Most everything tested properly but the MOSFETs didn't appear to test right. I replaced those with new and still no go. I also re-soldered most connections on the board. When I hook up leads to DC1 and DC2 I do not get any output voltage. If I leave a lead on DC1 and pull go to AC3 I get variable voltage based on where my POT it set.
I did pull the motor and clean the brushes. They appeared to be fine. When I put 12volts to it, it does spin.
The relays do click when it is powered up with the safety switch.
