I have a 20 hp mower gearbox that one of the gears is no longer available. Got a new shaft but the gear is worn in the bore and keyway. Can I put a layer of bronze in the gear and bore it out and make it work (last)? What about a Loctite product. Took the gear to a couple of local machine shops and they said they couldn't do anything with it because it was so hard. At this point I need to do something, even if it is wrong.
