Hooking up my vm. I have 220 going to my 20 hp rotary phase converter going to my vm.
At the power box 220 white is grounded.
I drove a 8 foot copper rod in the ground at the phase converter and grounded the convertor panel and generator.
generator wiring white ground goes to panel and ties into ground rod wire.
pic of 3 phase panel, Question 1 should I tie the 220 white ground in to the ground rod wire?, ground going to ground rod is bottom right black wire.
pic of vm power box .Question 2 . 3 phase Power cable going two the vm is grounded to ground rod at panel. Should the other end tie into a ground in the vm panel. Im thinking the small green wire behind the power cabel?
Im sure this is clear as mud so feel free to ask for any more info or pictures.
Thanks
mike
