WM210V adding 5C collets
weston1968
H-M Lifetime Diamond Member
Aug 29, 2016
121
I added 5C collets to my modified WM210V with ELS. The result was 0.02 mm TIR at the collet face ( cheap Chinese ) and .05 mm TIR at 100 mm from the collet face with a 25 mm bar. All error but .005 mm TIR is the lathe.
I used:
nose: https://www.ebay.com/itm/185925466872
draw bar: https://www.ebay.com/itm/185931620956
hand wheel: https://www.ebay.com/itm/283301126357
I also had piece of aluminum bar for the spacer.
The 8" handwheel had a hub that was large enough for a 1.375" hole. The hub is tapered so it can not be bored on a lathe. I used a milling machine. I drilled a hole in the approximate middle of the hub. I then turned the drill bit around in the chuck, lowered it into the hole and rotated the hand wheel. I used a dial gauge and marked the high and low. I then clamped the hand wheel with the drill bit still in the hole. I then dialed in the error and using a milling bit made a large pilot hole. After that I used a 1/2" collet and used 1/2 shank bit to drill up to 1 3/8". The draw bar was 1.377" so I had to put the hand wheel in the lathe, albeit with wobble and sand out to a sliding fit. The casting is very heavy and a little unbalanced and causes some vibration above 400 RPM.
The result is surprisingly good for this grade of lathe.
The flywheel effect of that big cast iron handwheel is liable to cause untightening of the collet when starting the machine, especially at a higher speed, I replace it with a much smaller diameter aluminum wheel, perhaps with some holes for a tommy bar or a pin spanner.
Yes, it did that. I have to make it goodntight. I can not find an aluminum wheel with a hub that will allow a 1 3/8" bore and set screws.
But you have a lathe. Obstacles become opportunities!
I am going to try printing out a plastic handwheel. STL attached. There are plenty of STL viewers out there for free. I am going to use M8x1.25 set screws with M8 knurled inserts.
  • handwheel.stl
