Hi all,
I recently cleaned up, repainted and re-greased a 70s wilton c2 combo vise, and now that everything's back together, I've noticed there's a fair bit of slop in the moveable jaw.
I machined a .030 spacer to fit behind the screw cover plate, which took up the axial slop on the screw. There's now minimal movement in the handle before the jaw moves in either direction - it feels nice and tight.
The issue I've noticed is that, when the mobile jaw isn't clamping anything, it's a fairly sloppy fit in the fixed casting. I can lift or rotate the jaw about 1/16" to 1/8".
I don't think this makes any difference to the function of the vise, but it's bugging me nonetheless... every time i start turning the handle, i see the jaw rack a little...
Is there anything that can be done for this? Or is it likely just wear between the mobile jaw tube and the casting? I looked at the keyway and key, and they both look ok to the naked eye....
Thanks in advance,
Lee
Sent from my SM-N920T using Tapatalk
Thanks in advance,
Lee
