Which vise should I consider
turbinedoctor link=topic=3128.msg22394#msg22394 date=1313627694 said:
Can a drill press vise work to the standards you seek in a mill vise?
Turbo
In a word - No. A machine (mill) vice is made to much closer tolerances than a drill press vice. The base, body, and jaws of a machine vice are ground to be (hopefully) perfectly flat, straight and parallel, and have smooth jaws. They also have a much greater force available for clamping onto the work than a drill press vice. You CAN use a drill press vice for drilling or very light milling on the mill, but they really aren't designed to withstand the forces that are encountered during milling operations.
Something you can do with a machine vice is to make your own jaws, and cut them any way you like. The jaws bolt on and can be removed / replaced. :D
Have a look at this video from MIT and it will give you a look at several work holding options you have for working on a milling machine. In fact, ALL of those videos in that series are well worth watching IMHO. Lots of good information presented about working with machines and tools.
turbinedoctor link=topic=3128.msg22410#msg22410 date=1313637384 said:
That answered alot of questions for me. ;0
Turbo
Yeah, it did for me too! ;)
