    Dismiss Notice
Which Quality For Surface Plate?
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by ybyo, Jun 29, 2016.
  1. ybyo
    ybyo Turkey Iron Registered Member
    24
    3
    City:
    istanbul
    State:
    Outside US / Canada
    -Return to Top-
    Dear all,
    First thing first i'm very new to forum so i would like to salute you from Turkey. My name is Yavuz and have mechanical engineering degree. I'm also hobby machinist, don't have a dedicated garage. Just working on my spare times in a dedicated room inside my flat.
    Nowadays i am looking for a granite plate in size of max 400x400 mm (~12 in) and reasonable weight to handle it. Just looked for suppliers and learnt about their different standarts, quality etc..
    One of them returned me that they have A and B grades in din 876 standart, also, for both south african and chinese stones. I think that A and B reffers to 0 and 1 grades in standart. (attached image)
    I would like to have your opinion, in my case which of them should i choose? I'm not so pro right now and my machines / tools are not in space engineering grade :) Actually i would like to have that plate for some bed way scraping. With a bit of limited budget i'd like have the most suitable one.
    Can you help me on that issue, would grade B (1) and chinese stone be so bad?
    thanks
    Uglydog likes this.
  2. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,194
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Yavuz, welcome the forum. I think you will find this a friendly and helpful forum.
    I am not so sure that your attached flatness chart corresponds at all to the grades A and B for surface plates, but I am in the US, and we have our own standards. Here in the US we also have grade AA, along with A and B. The tolerances are different for different sizes of plates, and also include repeatablility limits.
    http://standridgegranite.com/products/surface-plates
    http://standridgegranite.com/images/stories/docs/forms/fed spec ggg-p-463c.pdf
    What you need in a surface plate depends on what you are going to measure, to what tolerances, and to what repeatability. Grade B is commonly used for in-shop surface plates. If you plan to scrape things into higher tolerances, or do high precision grinding or layout work, you may want to go to a higher grade. Grade AA only really makes sense in climate controlled metrology labs. All that said, inaccuracies are to some extent cumulative, so a higher tolerance surface plate helps to build confidence in your home workshop measuring capabilities.
    In my opinion, everyone making accurate parts needs measuring tools including flat (surface plate), length (gage blocks), and angles [sine bar/table, known accurate square (certified granite angle block and/or cylinder square.)]
    You should be able to prove your tools and machines to your needed accuracy...
    4gsr, ybyo, Uglydog and 1 other person like this.
  3. Charles Spencer
    Charles Spencer Active User H-M Supporter-Premium
    869
    93
    City:
    Worcester
    State:
    Massachusetts
    -Return to Top-
    Firstly, please accept our condolences for the attack on your airport.
    Second, from your chart I see that the DIN876II is listed as accurate to within 1.06 mils (0.00106) in your chart. That's almost twice as accurate as the lower grade one.
    In my experience, when I'm not exactly sure what to buy, I have a simple rule: Never buy the cheapest or the most expensive. I use this for all types of purchases.
    I think I'd go with the one I mentioned above unless the price is really the most important factor.
    ybyo and Ulma Doctor like this.
  4. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    2,573
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    Hello Yavuz,
    welcome to the forum!
    i try this rule when buying, buy the best you can afford.
    you can upgrade later, if necessary, as your needs demand.
    sometimes you can sell the old items you no longer use to fund the purchase of something you will use.
    all the best
    mike:)
    Bob Korves likes this.
  5. Uglydog
    Uglydog United States Active User H-M Supporter-Premium
    1,028
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    Yep, consider your projected needs and your current budget.
    Get the best you can afford.
    But, also consider the sequence in which you need/want to purchase machines/tooling/inspection/etc equipment.
    Obviously, if the deal of the year comes along. then you may need to scramble.
    But, keeping priorities in line is critical.
    Also, (and don't tell my wife I wrote this) don't forget the kids need winter boots and breakfast.
    Daryl
    MN
  6. T Bredehoft
    T Bredehoft Active User H-M Supporter-Premium
    1,196
    113
    Central Ohio
    City:
    St. Louisville
    State:
    Ohio
    -Return to Top-
    At the level of precision I work, the cast iron top of my table saw is flat enough, I don't have, don't expect to have a surface plate.
    Ulma Doctor and Uglydog like this.
  7. Uglydog
    1,028
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    I've heard of others substituting plate glass.
    All depends on tolerances and application.
    Daryl
    MN
    thomas s and Ulma Doctor like this.
  8. ybyo
    24
    3
    City:
    istanbul
    State:
    Outside US / Canada
    -Return to Top-
    Thank you for your kind feelings, also same here about Orlando, Paris, Brussels, Ankara also.. A wicked universal thing.
    I think i will go with sum of your suggestions, top quality until to affordable budget (i dont need winter boots ;) ). But i think for hobby purposes 12x12 in^2 is more than enough.
    In the first time i will use it to take referances while reconditioning my lathe bed ways and gibs mostly. You see there are visible cutting left overs on gib surface, of course that's a cheap mini lathe i own (7x12).
    While making projects (double acting steam engine / bollaero diesel) i clearly understood required tolerances and finishing detail.
    Thanks again for your help, i'd like to join other issues and threads later.
    tweinke and Ulma Doctor like this.
  9. Wreck™Wreck
    Wreck™Wreck United States Active User H-M Supporter-Premium
    1,200
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    You are a hobbyist no? If so buy the lab grade surface otherwise you will always have fears about accuracy.
  10. Bob Korves
    3,194
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    If you are reconditioning tools and machines I recommend a grade A surface plate. The work on your machines will not be more accurate than your surface plate. Depending on price, you might choose an AA plate for peace of mind and a longer service life before it exceeds grade A standards.
    In my first post I was also going to give you my condolences over the violence you have been experiencing in Turkey. I did not, staying on topic, but I definitely do care about the safety of you and yours and indeed everyone on this planet.
    tweinke, Sandia and EmilioG like this.
  11. EmilioG
    EmilioG United States Active User H-M Supporter-Premium
    294
    63
    City:
    HUNTINGTON
    State:
    New York
    -Return to Top-
    I was looking at PrecisionGranite surface plates and they have some good new choices for smaller plates under $300.00
    I may go with one of these instead of buying a used plate of unknown accuracy. Black granite, 12 x 18 Grade A or B.
    Carts with caster wheels are $415.00
  12. Bob Korves
    3,194
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Precision Granite and Standridge Granite are sister companies. Their products are top notch. They are both made in the same plant. Here is a tour:
  13. FanMan
    FanMan Active User Active Member
    121
    43
    City:
    State:
    Connecticut
    -Return to Top-
    I use a 12" square piece of precision ground tool steel stock, which I cold blued with gun bluing for some corrosion protection and put rubber feet on. Accurate enough for what I need to do, small and light enough to store in a drawer of my rollaround, and mag base indicators stick to it.
    4gsr likes this.
  14. Pmma-Granville
    Pmma-Granville United Kingdom Active Member Active Member
    18
    8
    City:
    Colchester
    State:
    Outside US / Canada
    -Return to Top-
    Hello!
    Off topic but I like your avatar!
    Great machine the tiger 1!
    ybyo likes this.
  15. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    1,898
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    My first surface plate was a piece of 1-1/4 thick A-36 plate, 9 x 11, dad surface ground it on both sides and flipped it a couple of times called it good. Still have that piece of plate. Use it for ballast material in the bottom of one of my roll away cabinets.
  16. Wreck™Wreck
    1,200
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    A size and accuracy that are required by your particular work, no more no less.
    Took this at work today, 18" (450 MM) X 48" (1220 MM) X 96" (2440 MM), 6300+ Lb., .001" across according to the label.
  17. ybyo
    24
    3
    City:
    istanbul
    State:
    Outside US / Canada
    -Return to Top-
    I couldn't follow forum because of work/life stuff but i evaluated your recommendations and got an A grade japan made surface plate. I am pretty OK with that.
    In this time i also strugled with my 2 stroke compresion ignition project which i will share it in another topic.
    Salute!
    tweinke likes this.
  18. ybyo
    24
    3
    City:
    istanbul
    State:
    Outside US / Canada
    -Return to Top-
    Dear people,
    I found treasure at my old school. Actually i graduated from engineering department and this lab is for workshop which belongs to another institute. But seeing this stuff in that condition literally made me sad.
    There are lots of other tools most of them unused, calipers, height gauges, unopened gauge block set,microscopic edge finders, hardness testing stand etc.. Simply bad investment :(
    kvt, Uglydog and Charles Spencer like this.
Share This Page
