4
[How do I?] Which Lathe Setting for Finest Feed
3
Like what you see?
10
ARM
Active Member
Dec 8, 2011
268
Likes
71
#1
Hi Guys
Need courage to ask this. ( Obvious Answer to many) Has to be asked though, from what I am presently using as LCT1Z
What setting on my lathe would I use to achieve the slowest Finest Feed for Finish Turning.
Have attached a pic of the Face of the Lathe with the various Screw Settings
TIA
ARM
Active Member
Dec 8, 2011
268
Likes
71
#2
Sorry Guys.
Thought the pic would blow up to make the Screw Settings easily legible. Regret it's worse N U Guys won't be able read that at all. Unfortunately don't know which Size option to load ???
aRM
ARM
Active Member
Dec 8, 2011
268
Likes
71
#3
Okay, we got blown up pics of the Thread Charts. These will greatly assist. Here goes.......... 006.JPG 007.JPG 008.JPG
MozamPete
H-M Supporter-Premium Member
Jun 26, 2014
500
Likes
800
#4
LCT1W looks like the finest to me - 2 thou (or 0.05mm) feed per revolution.
You may also have to do a change to the gear train to change between threading and cutting feeds (top left of the face plate). Can't quite make it out but that is what I have to do on my lathe - you used to have an ML7 as well didn't you?.
RJSakowski
H-M Supporter - Premium Member
Feb 1, 2015
2,765
Likes
2,833
#5
It looks like your right chart in the first blowup picture is your feed chart.
LCT1W will give you .002"/rev.
It may be possible to get finer feeds by playing with the change gears I was able to get my G0602 down from .0025"/rev. to .0014"/rev. by changing one gear set fro 56/104 to 36/120.
ARM
Active Member
Dec 8, 2011
268
Likes
71
#6
Hello there Pete
Was worried U Guys would say that. Premonition of sorts as I tried earlier to engage those Gears. All meshed except the Long Numeral 1.
Will try again with the Jog Button. Hope it works !!!
Thanks a zillion. Know we are on right track now
LORD Bless
aRM
ARM
Active Member
Dec 8, 2011
268
Likes
71
#7
Hello RJ
Assume U also have a 14" lathe.
What U said concurs with Pete. Now we need to make these Gears mesh. Will give that another go.
Will also check the additional Gears which came with the Machine.
Much appreciate the quick response
LORD Bless
aRM
RJSakowski
Feb 1, 2015
2,765
Likes
2,833
#8
I have a 10 x 22 but the same principle applies. Smaller input and larger output gears equal finer feed. I am using my inch/metric transposing gear for the output gear.
mksj
Jun 12, 2014
1,451
Likes
1,634
#9
This lathe appears identical to the Grizzly G0509G. The manual is attached, although they have an error on the metric feed rate (P31) which was corrected on your model gear plate. There are no additional change gears, just one transposing gear which is a 44/56T. They give directions in how to change Feed/Leadscrew gears and that the gearbox should be in neutral "I". If I have difficulty engaging a gear, sometimes I will engage the gearbox feed, spin the gears by bumping the jog (momentary) and then changing the gears before the machine stops. You can also rotate the chuck by hand with the gearbox feed engaged and jiggle the gears change lever to the desired setting. You seem to be having problems getting the gears to mesh in the desired feed rate. LCTW2W will give you a feed rate of 0.0022 which could also be used. If it is difficult to shift the gearbox there could be a shift rod or fork problem, might also benefit to change the gearbox oil if something is sticking.
ARM
Active Member
Dec 8, 2011
268
Likes
71
#10
Hi Guys
Just to report back, tried all the Settings in the LCT1-8W designations. None of them meshed at all. It seems that we definitely need to change some Gears, if we can can trace specifically which. Any idea which would they be ??? I reckon that they just might be the lower small Ones. Will need get a shot of the innards of our Lathe.
Thanks again
aRM
ARM
Active Member
Dec 8, 2011
268
Likes
71
#11
Hi MKSJ
Thanks a stack for that beautiful comprehensive Manual. What a world of a difference in comparison to mine, which is quite old anyway. Will make a hardcopy and study it thoroughly as there's lots there worth revising and learning from.
And will go down on the morrow to ascertain exactly what Numbered Teeth Gearing is installed and the additionals that came with the machine. Will also check our Oil levels and maybe do a change there as well, 'cos it has not been changed since getting the Lathe.
Like I mentioned earlier, there seems to be no "Meshing" at all in the "W" Settings no matter what I tried, and hopefully it ought to be the Gear U referring to, IA.
Much appreciate the time and trouble U so kindly took to post that copy of the Manual. I was really chuffed to receive such an instructional version.
It will indeed come into good use.
Warm Regards
LORD Bless
ATB
aRM
mksj
Jun 12, 2014
1,451
Likes
1,634
#12
Not a problem, please review the manual carefully. They indicate that the lathe must be in the neutral "I" gear position to change the gears, they also say to bump the jog. If running, it must be in neutral under 500 rpm. I am not familiar with this lathe, but sometimes it is hard to get the gears to mesh. If all the 1-8 gears do not mesh, then it may be a problem with the W gear. There are forked shifters and rods, sometimes something gets bent or needs alignment. Do not force anything.
Chipper5783
Sep 25, 2014
565
Likes
406
#13
"What setting on my lathe would I use to achieve the slowest Finest Feed for Finish Turning."
I hope this does not come across sounding stupid: "What is the purpose of your question?"
Are you just trying to understand the various levers and settings of your machine? Is your goal to machine directly to a good surface finish (no polishing step)?
You do understand that a very fine feed rate does not necessarily produce a nice finish (in fact, quite the opposite). My finest feed rate is 0.0015" per rev - I very rarely ever use that feed rate (for finishing I'm generally about 3x that, but there are many other factors that go into cutting to a good surface finish).
ARM
Active Member
Dec 8, 2011
268
Likes
71
#14
"Tis now becoming all the more obvious that there definitely is a gear problem with my Machine. I omitted to mention that we could not cut 1.5 mm Threads previously as we also encountered a problem with the Long Numbered Lever. We will now have to, perforce open some of the covers and look into ascertaining the issue, from our limited experience with these things. Alternately, we would have to get professional assistance.
Thanks again for the guiding response.
ATB
aRM
ARM
Active Member
Dec 8, 2011
268
Likes
71
#15
Hello there, Sire.
Yes, indeed. We need to thoroughly know our machine together with its capabilities and or limitations to achieve the finest results possible. Yes again, we have been doing Polishing and would not give up that step at all from the beautiful results obtained.
However, without using our machine to its maximum, we would not know what results would at all be possible. We would not disagree with your kind self on Feed rates. Nevertheless, we may mention that ours is a robust machine indeed on which we have literally burnt HSS Cutters and restrict ourselves to Carbide Inserts only. Again, this maybe our total lack of knowledge on Speeds, which we cannot argue on. The truth of the matter is just that we have been watching numerous You Tube Machinists and are blown away by the beautiful finishes obtained with most using Inserts on big machines similar to ours. Without actually trying this out on my Lathe, I really would not know what the difference would be.
And now because of this new adventure, it has surfaced that we indeed have a problem with our machine that needs attention, which we really hope is not too serious to drastically affect our pocket at this point in our lives, IA.
I sincerely hope this has not come across any more pedantic nor brash than it is, and You would literally take it at its surface value.
Thank You Sir, for taking the time to respond and affording us an opportunity of a totally different perspective.
Much appreciated
ATB
aRM
Chipper5783
Sep 25, 2014
565
Likes
406
#16
I looked up your machine C6241 - it looks like a pretty standard 16" industrial machine (around here it is branded "Modern" but it is likely sold under a number of brand names). I'm not really understanding the comment about issues with HSS tooling - there is no reason HSS won't work fine. Burning up HSS tooling is an operating issue. Of course carbide can handle higher temperatures and harder materials. Carbide has real down sides too, it is not as keen an edge, there is more tool push, there is less back rake and it is prone to chipping (less forgiving). HSS is a great product, properly applied you can get an excellent surface finish (in fact that would be one reason to use HSS instead of carbide).
Most any material will finish out to a nice surface, but some are much easier to get a good surface than other materials. There are many resources available to recommend the starting point for speeds, feeds and depth of cut. Use about 75% of the recommended value as a starting point. Then, use your roughing cuts to figure out good speeds and feeds to get a nice finish. When you have about 0.03" to go, figure out the depth of cut so your last 3 passes will be the same (i.e. say 0.010" each). Of course, take a measurement after each pass and adjust as needed. The point here is that trying to take a cut of 0.001" depth is difficult to achieve a good finish - especially when using carbide (with HSS you can often get away with a lighter cut - because of the keener edge, more back rake and less tool push).
Let us know how you make out. David
grumpygator
Gatekeeper
Staff member
Administrator
Sep 18, 2012
1,152
Likes
825
#17
Have you tried a spring cut ?? IE, when you get to the end of the cut put it in reverse and go back without changing the DOC...
**G**
ARM
Active Member
Dec 8, 2011
268
Likes
71
#18
- there is no reason HSS won't work fine. Burning up HSS tooling is an operating issue. HSS is a great product, properly applied you can get an excellent surface finish (in fact that would be one reason to use HSS instead of carbide).
Let us know how you make out. David[/QUOTE]
Hello David
As I see it, one of the main problems for me as a novice to Machining is the total lack of experience with correctly Sharpening HSS Cutters, combined with, as U have correctly stated above, having "operating Issues". Being frustrated with the poor quality of edges obtained, HSS was quickly abandoned as an easy alternative to Carbide, which was available in numerous configurations to suit. It's just circumstantial that we have not had access to some practical tuition or guidance in this major side of Cutting Technology. "Tis only of recent that we have seen the You Tube community grow by leaps and bounds where these "Creators" show and share their experiences in all these aspects. Reading all the books in the world has not really helped without the practical demonstrations. On retrospect, methinks it is a bit late into machining for us (to go Back) and start to learn proper HSS Sharpening. But then I guess, that's what "Back to the Future" is all about.
That is a very good suggestion of Yours to try 3 Passes of the remaining 0.76mm of Cut. We will definitely give this a shot and let U know in this regard.
For now we have to tackle our Gear Feed problems with our machine, which we are dreading, as we need to open the covers and try to ascertain the cause with the little background and knowledge of these things, which we have. Oh Well, that's another issue, so here goes .....
Thanks again for the kind response.
Much appreciated
ATB
aRM
ARM
Active Member
Dec 8, 2011
268
Likes
71
#19
**G**
Hello Sir "G"
Yes Sir. We are indeed familiar with and have heard that word numerous times in threading as well. I'd say it's origination is more American than other worldly. Mind You, we don't recall trying it out for Finish Cuts on the Lathe though. Been using it often on the Mill surprisingly. It's makes much sense and is also a very good suggestion on Your part.
Thank You kindly for the good prompting
LORD Bless
aRM
ARM
Active Member
Dec 8, 2011
268
Likes
71
#20
Hello MKSJ
Another silly but quick Q please ..........
How do I remove the covers for the Emergency Stop Button(RED) and the others in that line
Need to open and look into the Gear non-Meshing problem
TIA
ATB
aRM
ARM
Active Member
Dec 8, 2011
268
Likes
71
#21
**G**
Hello Sir GG
Just a follow up.
Did some boring over the weekend and tried Your Spring Cut on Reverse Feed
Guess what .............???
U think it worked on my Lathe >>>>???
Kill the suspense...........
You're a real Ol' Pro GG. A Master no doubt.
What a beautiful smooth silvery finish. Truly glorious to behold. Pity it was a small Diameter Bore (30 mm) otherwise I would have added some pics to gladden Your heart.
Muchas Gracias and Thanks again a Zillion. What would we do without U Guys !!!
ATB
aRM
PS: Now to battle to open the machine front Covers. The excitement just don't end.
6
5 7
