Where to get the best price on flat leather lathe belts?
O
ome
Forum Guest
Register Today
Hi Guys,
my 11" Logan will need a new leather belt, i just bought a bench flat belt lacer to use the clip method.
The original belt is glued.
I am also confused as to which side is up, not on the pulleys.
Also, can one use a narrower belt to replace a wider one.
Lastly, which side of the belt faces up?
When i bought my logan 6 months ago, the flat belt on the cone pulleys was with the shiney side facing up , but when a couple of buddies came by to help me , they noticed the belt was on incorrectly, so between the both of them and a 10" screwdriver, they were able to reverse the belt.
Now the smooth or fur side is against the pulley, with the flesh side facing up.
Any info greatly appreciated,
jon
It has always been said the flesh side goes to the pulleys. If your lucky an got a Graingers near by they have clips. Although Clipper has
a site, but the confusion is the numbering or lettering system for the clip size. Like buying a pair of shoes confusing. shoe sizes dont seem
to match anymore.
The flesh side runs against the pulleys. When I had need for leather belting,I laced them together with a continuous length of copper wire of a fairly thick gauge. Holes were drilled to receive the lacing,and grooves were cut on the flesh(pulley) side of the belting. The copper wire sank into the grooves and did not click when it ran over the pulleys. Do not groove the hair side of the leather as most of the strength of the leather is in the hair side.
We have a co. called Hampton Rubber in this area. They carry a surprising number of things,including fabric impregnated belting that will not keep stretching forever like leather will. It might be wise to locate such a co. near you,and go and see what kinds of artificial belting material they might carry. Leather can be a pain since it keeps on stretching,and you have to keep re locating the stitched joint.
That's a new one on me folks. We always ran the rough side to the pulleys. I'm not saying you can't, I'm saying we never did.
"Billy G"
"Billy G"
Hi Bill,
Thanks for giving your opinion, i do appreciate it.
now i am confused because my buddy has been doing this for over 25 years as a hobby and is atleast 70 years old and has refurbished all sorts of old machine, and his buddy say flesh side on the pulley.
Which is the correct way and why?
thanks,
jon
Old Engine website Paragraph 22
http://www.old-engine.com/belts2.htm
South Bend lathe bulletin pg. 2
http://www.wewilliams.net/docs/Belt Splicing Instructions - Bulletin No 600.pdf
Wikipedia 3rd paragraph of flat belt section
http://en.wikipedia.org/wiki/Belt_(mechanical)
RustyIron.com 2nd paragraph
http://www.rustyiron.com/Articles/beltingnotesandr.html
Machinery's Handbook 16th edition pg. 938
"The maximum pulling power is obtained by running the grain or hair side of the belt next to the pulley faces."
Just thought I'd throw out another possible source for belting Al Bino Machining and Custom Flatbelts
I've been very happy with the "composite" belt I've got on my 11" SB but he also offers leather belts as an option.
FWIW - I've only ever seen "flesh-side down".
-Ron
Just to through out another option, if your not being a purist, a serpentine belt ran inside out works well as a flat belt. they come in all length and widths.
Greg
Greg
Thanks Greg,
do u use clips to put it on the lathe?
thanks,
Jon
