- Nov 25, 2015
- 8,389
that's set up as a left hand turning tool. You want a right hand tool. What's happening is you are not getting close enough, and its acting like a forming tool, you have a lot of metal engagement. You want less.No, I'm not threading, just turning off the existing threads for length of 1/4-1/2" and need a good remaining 1/2-13 thread. If I use the DCMT or brazed carbide it galls the thread so I cannot easily thread on a nut after cutting the chamfer.
Set screw is 2" long. Running 4-500rpm. They are fairly hard but I can file them. Chips are little dark bluish curls about 1/8th inch long. Need to do 100's.
I prefer to do the cut and 45 degree chamfer with the one tool.
Right now I do one pass to get 90% of the material off, then 2 spring passes to dimension
Thanks, I'll checkout that HSS at KBC. I'm also looking at these: https://www.aliexpress.com/item/4001294281524.html?spm=a2g0o.9042311.0.0.2bc44c4dMNwtv9
See photoView attachment 396413
if that were the short side on the left and the long on the right it would be better. But really I would want something almost straight on the left, and slightly relieved on the right. I have a cutter like that and use it for things like this. It has no problem cutting socket head and set screws.
