    Dismiss Notice
Wheel choice for Quorn Tool & Cutter Grinder
Discussion in 'TOOL GRINDERS & SURFACE GRINDERS' started by old toolmaker, Apr 27, 2017.
  1. old toolmaker
    old toolmaker United States Active Member Active Member
    32
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    I just completed my 11 year build of the Quorn Tool & Cutter Grinder and am wanting to acquire a couple of good grinding wheels for general purpose high speed steel grinding. I have a 150 grit Diamond with CBN wheel that is slow at metal removal when grinding high speed steel but works OK on carbide. Are there any suggestions? Any comments on my current wheel?
    Thanks, Dick
  2. Dave Smith
    Dave Smith United States Active User H-M Supporter-Premium
    134
    63
    City:
    Rochester
    State:
    Minnesota
    -Return to Top-
    Dick----don't use your diamond wheel for steel -----just for carbide---a soft white wheel works best on HSS tools---Dave
  3. rgray
    rgray Active User H-M Supporter-Premium
    309
    83
    City:
    Helena
    State:
    Montana
    -Return to Top-
    I've been using a white 46J cup wheel 4"- 3"x1 1/2"x1 1/4" on my tool grinder. I use a spacer in the center for the 1 1/4 hole size. Found them on ebay cheap. so making the spacer was worth it.
    Works good on HSS.
    rdhem2, Rustrp and Dave Smith like this.
  4. old toolmaker
    32
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    Dave,
    I will reserve the diamond wheel just for carbide as you said and I will shop around for a soft white wheel.
    Dick
  5. old toolmaker
    32
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    We used to use 46H on our 618 surface grinders for our general purpose wheels so I think it might be well to have a 46 J hardness at least for roughing. Maybe a 60J or 80J as well all mounted on their own 8mm collet arbors which is what my grinder spindle uses. No need to dress between uses.
    Dick
  6. old toolmaker
    32
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    I have an 80 K which seems a little hard for roughing. It requires frequent dressing to keep it sharp and grinding cool. I think I will try to get a 46 I or 46 J in a 4" straight cup white wheel for material removal and for use on lathe tools.
    The Quorn has removable wheel arbors held in by a draw bar so switching out a wheel is very quick as they run true once dressed and they require no re-dressing as long as they are in good shape.
    Dick
  7. Dave Smith
    134
    63
    City:
    Rochester
    State:
    Minnesota
    -Return to Top-
    sounds good Dick, when the white wheels get worn beyond use---you can hold them by hand to your diamond wheels and they will clean the diamond wheels to be just like new----Dave
    f350ca likes this.
  8. old toolmaker
    32
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    Thanks for the advice, Dave.
    I was also thinking of a ceramic wheel although they are somewhat expensive. I have never used one but I have read that they grind cool and stay sharp much longer.
    Dick
Share This Page
