- Feb 17, 2021
- 471
I've had very good luck with 1/2" shank router bits. Much cheaper than anything marketed for metal.As long as you can mount it securely in your tool holder, it should work with just about any size stock, as @MrWhoopee posted. It's just another form tool ... and be alert for chatter, etc. The one you picture looks like it would be best for aluminum. If you want to do lots of steel, I'd suggest a carbide insert roundover bit ... maybe one with a 1/2" shank (for additional strength/stiffness).
I have wondered about router bits. At the cutting edge, are there any fundamental differences in clearance angle, and back rake angle, etc ?I've had very good luck with 1/2" shank router bits. Much cheaper than anything marketed for metal.
I can't give you anything definitive, but the back rake is zero (face of tool is parallel to axis) and clearance seems to be greater than tools ground for metal. That may just be perception because of the small diameter.I have wondered about router bits. At the cutting edge, are there any fundamental differences in clearance angle, and back rake angle, etc ?
That you simply went ahead, and tried a router bit, and it worked OK is very telling.
I get it that many mill tools have spiral flutes, but if router shapes work just fine, how come they are marketed as "woodwork" ?
