    Dismiss Notice
What Size Surface Plate
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by ddickey, Jul 15, 2017.
  1. ddickey
    ddickey United States H-M Supporter - Premium Content H-M Supporter-Premium
    355
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    I'm considering a surface plate purchase. Looking at a 9" x 12" that Lee Valley has for sale.
    Checked E-Bay and see a lot of 12" x 18" plates. What size do you guys have? Is 9" x 12" considered a very small plate?
  2. Ed ke6bnl
    Ed ke6bnl Active Member Active Member
    124
    43
    City:
    Agua Dulce
    State:
    California
    -Return to Top-
    I put in a very good ebay bid on one I think 18x24 BECAUSE I could go there and pick it up BUT it took two people to load and unload safely.
  3. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,394
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    What do you plan to use it for, Duane?
  4. ddickey
    355
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    I would like to learn how to properly use one, layout & measuring parts to check flatness on various projects. I have a surface grinder now so think it would be a nice addition for checking ground parts. So far my projects would work fine on a smaller plate I think. The plate would be kept indoors.
  5. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    2,723
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    i'd get the largest plate that's convenient for your shop space and scope of work.
    there is not much worse than needing a larger anything! :)
    the cost difference between a 9x12 and a 12x18 are negligible if broken down over the lifetime of the plate.
    unless you are doing high precision work a grade B will be sufficient
    Rex Walters, darkzero and Bob Korves like this.
  6. Bob Korves
    3,394
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    To check parts and tools you will probably need some kind of height gauge for dimensions, a surface gage with indicator to compare parts with each other or with gage blocks, and a cylinder gage or granite square for checking squareness. For layout you will need the surface gage with a scriber and the height gage and some spring calipers. Not all of that stuff needs to be on the plate at once (or even ordered right away), but there needs to be room for whatever part you want to work on as well as the tools for layout or testing. You will run out of room pretty quickly on a 9x12" plate unless you only work on really small stuff. I have a 18x24", it has comfortably handled everything I needed to do so far. The biggest thing so far has been spotting my 8x16" cast iron surface plate for scraping it in. I have also calibrated straight edges up to 24". I assume you are looking at Chinese import surface plates. They can be really good, but not always due to lack of quality assurance, and there is no way to know, and no reasonable way to test it yourself. The small plate is fine for starting out, but at some point down the road you may want a bigger plate to handle bigger parts, and one of known and tested accuracy so you can calibrate your tools properly and with confidence.
    Edit: The smaller Chinese plates make good lapping plates for general shop work.
  7. ddickey
    355
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    Thanks for the info. Exactly what I was looking for.
  8. francist
    francist Canada Active User H-M Supporter-Premium
    583
    93
    City:
    Victoria
    State:
    British Columbia
    -Return to Top-
    I have a 9 x 12 from Lee Valley. Nice enough plate and I'm not dissatisfied with it, but it is small. To give yourself an idea, put an ordinary piece of printer paper on your bench and play with your layout tools on it and maybe a dummy part. The paper is 8-1/2 X 11, the plate is 9x12. If you find the paper area is feeling cramped, so too will the plate. Using bluing (for scraping) would be a challenge too without covering the entire plate surface.
    Like I said, I'm not unhappy with the 9x12, but it will not be my one and only.
    -frank
  9. darkzero
    darkzero Global Moderator Staff Member H-M Supporter-Premium
    1,302
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    I've got a 12x18, I don't inspect parts a lot but I personally wouldn't want anything smaller. Put a height or surface gauge on it & a lot of space is taken up. Mine has ledges so it's easy to pick up & move around if you need. Mine just sits on my workbench.
    I do also have a 9x12, as mentioned it's basically the size of a sheet of paper which is why I bought it. I use it for lapping, perfect size to glue or tape a sheet sand paper to it. I have this one sitting in an aluminum baking pan to catch the water when wet sanding.
    I'd really like to have an 18x24 but they cost a lot more. My 12x18 is a grade A that I got for $37 at Enco. My 9x12 is a grade B, $33 from MSC. Those are Chinese grades though. :)
  10. Wreck™Wreck
    Wreck™Wreck United States Active User H-M Supporter-Premium
    1,248
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    If you plan on measuring parts that are 60" long then you will need 60" of surface, no less no more.
    If you are a hobbyist you probably do not need a surface plate of any size, what kind of work do you do anyway?
    Fitter Bill and mikey like this.
  11. ddickey
    355
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    Just a hobbyist. Maybe someday it could turn into something more.
    I just think it would be good to have a nice flat reliable reference.
    Bob Korves likes this.
  12. projectnut
    projectnut United States Active Member Active Member
    24
    18
    City:
    Madison
    State:
    Wisconsin
    -Return to Top-
    I've had a 10"x18" for several years and have always thought it was too small. Earlier this year a friend was downsizing a commercial shop. He had a 36"X 48" and 24" x36" granite plate, and a 24" x36" cast iron plate. He kept both the granite plates and sold me the cast iron (Challenge brand) one for an excellent price. I now have a plate that can handle almost anything I need to measure.
  13. Wreck™Wreck
    1,248
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    True enough, however there are probably better ways to spend money so buy a plate when you begin doing work that requires one.
    If you are Hooked On Accuracy© a plate may open a can of worms that you do not expect.
    Rex Walters and mikey like this.
  14. f350ca
    f350ca Canada Active User Active Member
    1,519
    113
    City:
    Calabogie
    State:
    Ontario
    -Return to Top-
    I have the Lee Valley 9x12. Its adequate but I plan on getting a 12x18.
    Greg
    mikey likes this.
  15. mikey
    mikey Active User H-M Supporter-Premium
    2,141
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    Duane, if you have a Woodcrafter store near you, they sell a Grade A 12 X 16 surface plate for under $100.00. It comes with a surface map. I just bought one of these the other day. I also have a 9 X 12 Starrett toolmaker's flat and it is very good but I use it mainly for laying out, not for gauging stuff on.
  16. wawoodman
    wawoodman himself, himself H-M Supporter-Premium
    573
    113
    Seattle, WA
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    I have an 18 x 24 x 3 that I got on the local Craigslist. Back then, I could move it myself, admittedly, with difficulty. Now, not so much.
  17. Rex Walters
    Rex Walters Active Member Active Member
    184
    43
    City:
    Los Gatos
    State:
    California
    -Return to Top-
    I'm happy with my little 12" x 18" plate. It's large enough for pretty much everything I do and doesn't take up much room in my shop (clear flat surfaces are at a premium!). Any plate is better than no plate, but I'd be frustrated if the only one I owned was any smaller than what I have now.
    I only have one thing to add to everything that's already been said: no matter what size your plate, you should rest it on three points. To go the extra mile, you can put the rests on Bessel points, but that's not nearly as important as ensuring the bottom is resting on a flat plane. Three points guarantees a flat plane.
    Even a 4" thick piece of granite can eventually get out of flat if you just rest it directly on, say, a child's desk with a thin 3/4" sway-backed wooden top. But only a complete idiot would do that. :rolleyes: (I finally realized the error of my ways.)
    For a small plate, up to say 18" x 24", any three small pieces of metal or wood placed somewhat evenly inbound from the edges will suffice. I've just got three chunks of scrap wood under mine, but have considered using some 1" steel balls with a flat milled on one side. If I ever do go that route, I'll probably put the flat sides against the bottom of the granite and the round bottoms against the table to avoid putting too much point stress on the granite.
    For a larger plate you should locate the 4 Bessel points to support the plate. Two of the points should be supported directly. The other two should be supported by a rocker arm of some sort, and then the center of that rocker arm supported. That gives you three points of rigid support to define a plane.
    I understand that better plates have the Bessel points already marked on the underside, but you can calculate them yourself pretty easily. Just measure each dimension, length an width. Multiply those dimensions by 0.5594 and that should be the distance between the support points (just measure half those distances from the center lines to locate the points).
    A real support stand should also protect the corners of your plate to prevent anyone from knocking it off the proper support points.
    Dale Derry has a nice series on the stand he built for his plate.
    4gsr, mikey, f350ca and 1 other person like this.
Share This Page
