I think that $1k may be just a bit too much for this machine. A 9C does not have a power cross feed and uses the half nut for its longitudinal power feed as well as threading. If it doesn't have all of its covers, it becomes even less desirable to me. Another thing is what does it come with in terms of accessories. Something else to look for is the size of the motor. It looks like it may be a short bed. Starts to limit what length you can work with. As far as capabilities it can do most anything you want if you don't mind changing gears every time you want to change feed speed. To me as depicted I would not give more that $500 or so, maybe even less.
Paul
