What Is This Worth?
Finster
Jan 28, 2016
253
This was an e-bay auction for $150." lot of 100 Niagara Endmill End Mill 5/16 x 3/8 x 3/4 35100 HSS4" Supposedly, they were used only once to cut plastic and are like new. They do look like new. In the pictures, you can see where there is some plastic gummed up on the end of some of the bits. Sorry, I can't post a bigger picture, if you want to see, you'll have to google it.
So are they worth $1.50 each? I believe they are all sharp. There doesn't seem to be any wear (looking at coating on the ends" unless the plastic dulled them.
Copying and pasting your quote doesn't lead to the original ebay images. If they are virtually brand new, that would be a good buy. But, you'd have a lifetime supply of one particular size. They are certainly worth $1.50 each if you can use them. It's really up to you to decide if they are a good bargain for you. If you have some "fun" money to spend, go right ahead.
Cheers... :)
Brian
Cheers... :)
Brian
Well, the plan is to inspect them and if they are like new, I'll resell a bunch until I get my money back. I'll keep what's left. I figure that I'll end up with about half of the lot.
From my experience, it's probably a little bit high for a big lot like that, as they would normaly go for about a buck a piece. I've bought multiple lots, and depending on size and composition of the lot (big end mills and carbide tend to be a bit higher) they seem to run about a buck. If these are as good is claimed, then they would be worth it, but you won't know until you get them. Check out the sellers feedback. If it is near 100% with quite a few ratings, then it's probably legit. Any eBay seller below 98% is considered a deadbeat. Any way you go about it, buying used cutters is a bit of a gamble.
Yep, I agree. This guy is at 100% review with 379 reviews. I'm thinking I'm safe. I'm going to try and sell 10 pc lots starting at $25 or $30 bids if they are in "like new" condition. I think I'll be able to get rid of them in time. If not, it's only $150. Not like I have to sell the house. Live and learn.
About 6 months ago I bought the same (type) article, (4 flute 5/16 TiN coated one end mills), ten for $8.95 inc shipping. I'd be hard pressed to spend $25 for another ten.
If you resell/flip them on fleabay and if that buyer has any savvy at all. That buyer will notice the original source of the end mills and note that the original seller has been selling MANY lots of 100 of those end mills. And the buyer that is thinking of buying yours @ +$2.50 each will probably instead buy a 100 @ $1.50 each from the original source. And franky, selling to someone with other than savvy on fleabay, like from outerspace (slang), just ain’t worth it. The oneway feedback system and return policy is the deal breaker for selling to buyers from outerspace IMHO.
that's a lot of work to get a bunch of endmills all the same size. I'd rather spend $20-30 on a grab bag of different sizes, or even $10 on a set of 5 from China.
